i have a paradigm cc450 which i want to hook to my sony str-dn610 how? the sony receiver only has 1 output for a center speaker but the paradigm has 2 sets of connectors. my receiver specs says 4 Ohm/8 Ohm Switching : No(8 Ohm only) so i assume i cant just slit the wire into 2 coming out. the receiver has a biamp thingy going on but to use it i would lose my back surround speakers. is there a way to use the paradigm with this receiver or should i not try? also the gold plates that should be under the input terminals on the center speaker have been removed does this matter? here is a link to my reciever specs http://store.sony.ca/webapp/wcs/stores/servlet/ProductDisplay?catalogId=100803&s toreId=20153&langId=200&productId=8198552921666232797#additionalImage2
i dont have the jumper plates. to split my wire and attach to both sets where would i split the wire? where it connects to the receiver or the speaker? is this gonna effect my 8 omh thingy? i read that if i split the wire it will cause the 8omh to change to 4omh on each speaker? am i misunderstanding this? could i just take 2 sets of wire and twist em together then insert them into the receiver terminal or is that gonna blow up my receiver?
Yep! You're misunderstanding it. If the speaker has a system impedance of 8 Ohms, then the receiver is looking at an 8 Ohm load when you connect the entire speaker system. There are exceptions to this rule but, for your purposes, that's the rule you should use in this application.
Cut off small pieces of your cable (3" or so) or go get some other sort of cable to use as a jumper between the two input connectors. I think Audio Advisor sells better than average jumpers for a few bucks. Look on their web site.
Just make sure, if you use stranded cabling, all of your connections are clean and tight with no stray conductors peeling off from the connector which could cause a short circuit. Strip off just enough insulation to make the connection. Wrap the bare wire around the post slightly in the direction the connector tightens (clockwise) before you begin to tighten things down. You can usually take the shaft of a small screwdriver and pre-bend the wire around it to fit snugly over your connector post.
You can go to Radio Shack and buy a spool of 18 gauge solid core hook up wire for a few dollars. Buy a cable stripper with the wire and this would be a highly acceptable jumper with no possibility of stray conductors shorting your your amp.
