Aux cable into tv
Username: Jenkinsmw
United Kingdom
I recently bought a tv, but the in built speakers aren't great.
I have good speakers, but their output is through a single aux cable (same as say a pair of headphones).
The TV has two (left and right) output plugs, how can I connect the speakers to the tv? Is there a cable which can act as an adapter to change the aux cable into a double headed cable for the tv?
Thanks
Username: Jan_b_vigne
Dallas, TX
Post Number: 17581
I assume the two outputs on the TV are RCA's. You'll need to run an interconnect cable to an external amp which will power separate speakers.
Username: Lletsinger
my tv has 2 rca outputs (red/white) and the iLive sound bar has 2 rca input ports, but even with a direct cabling from the tv to the sound bar, i get no sound output from the bar. the cables have been tested and are good. what settings should i have on the tv (an rca tv/dvd combo) that will allow the sound to come thru the sound bar??
the rca tv model is LED32B30RQD.
thanks for your help!
lee
Need to Register?
Forgot Password?
Enable HTML code in message
