New member Username: B_bog81Post Number: 1 Registered: Nov-04 | Please help! I need a code for my cass (Opel) Philips Car 400 ( model: GM 90506173, PA6-GF15, 1614438 Philips). Baba_Bogdan22@yahoo.com if anyone know the code ! Thanks |
Unregistered guest | please help need code for my car (opel vectera) i don' find my cade member for my radio cassette pilips car 400 because my batérie is deed my radio need a code for 4 number |
Unregistered guest | How do you put in the known code into a Philips S200 car radio, Please! |
gian52 Unregistered guest | aiuto!!!ho dovuto staccare la batteria ora mi tovo con l'autoradio car400 :leggo 7safe ed e' bloccata no riesco ad inserire il codice a 4cifre in mio possesso sicuramente devo aver sbagliato si puo' resettare? come? moltissime grazie anticipate |
Anonymous | Ho comprato una Opel corsa usata ma non sono riuscito ad avere il codice della autoradio montata, una Philips DC 247, e non posso quindi utilizzarla. Qualcuno puo essere di aiuto? Grazie in anticipo. |
Unregistered guest | Hi there! I've got a problem with my Philips CAR 400. As usual for this radio I lost my RADIO PASS and so the CODE to unlock the radio. Who can help me? The S/N is GM0400T1449138. Other numbers on the bottom of the radio are No.: 90 532 621, 2F3, the Barcodes: 9022 213 96752 00 and 003 9651 1449138. Please help me. Regards Claus |
ankur Unregistered guest | Anybody knows free site for code of phillips car 400 |
Santas little helper Unregistered guest | Should help you all |
Unregistered guest | i have philips 400 car radio. i swich off from the battery and now i can`t restart the radio. please tell me how to enter the code and establish the radio again? |
michal Unregistered guest | my radio has code 0635. hope it'll help. |
ADY GRIFF Unregistered guest | Hi,HELP I need some help with code for my philips car 400 the number is GM0400Y2823452 I have lost the card with the code on .OOPS. |
Unregistered guest | my radio number is GM0400Y2859189- code reqd if possible |
New member Username: KomaBelgrade, Belgrade Serbia Post Number: 1 Registered: Aug-05 | Hi all I have a question to ask... I need a radio code for my Philips car 400 out of a Opel Vectra 98 NO 90532621 Type car 400 2F3 I also have a number on back of my radio: WA019727 please help i need it very much!!! thanks!!! thanks!!! thanks!!! |
Unregistered guest | I need an unlock code for a Philips RDS model 22RC200/35 the serial number is PHACFFX9037865. I would be most appreciative forany help |
Unregistered guest | Hi all I have a question to ask... I need a radio code for my Philips car 400 out of a Opel Vectra 99 NO 90532621 Type car 400 2F3 I also have a number on back of my radio: WA049937 GM0400X2512326 please help, thanks!!! |
Unregistered guest | Hi there, If anyone can help I would be eternally gratefull. I have a Philips CAR400 Taken from my mums Vauxhall Astra Estate.We had to disconnect the battery, and so lost the code. the number on the side is: GM0400X2569162 the 2 barcodes on the top are: 90222139975900 00399422569162 I tried other sites, but they couldnt find the code. Thanks in advance! |
Anonymous | hey i need a radio code for a phillips 400 code number thing is GM 90506173 cheers |
Unregistered guest | Have a phillips CAR 400. Please advise where to find the S/N. |
Unregistered guest | hi my old opel corsa have a battery low, and the Philips Car400 is in "CODE" security.. the radio have a 1st barcode 9022.213.96752.00 and 2nd barcode 003.9645.1419070, another number GM0400T1419070 and another DC396/75E 2WA00 29.10.96 please what is a right security code? |
New member Username: GiomaPost Number: 1 Registered: Sep-05 | Hallo, I changed batteries on my Opel Vectra and the radio asks for the code. can't find it any more. Car dealer asks for payment to give me the code again :-( Model No 22 DC 347/78 Prod. no. FD 0997459057702 aszxqw at libero dot it Hope you can help, thanks Gioma |
Bicska Unregistered guest | I think you need this: http://www.eserviceinfo.com/downloadsm/18226/_.html |
rafi Unregistered guest | Hi, I also need code for my radio. I've had the LPG installed in my car and they had to disconnect the batery My numbers: GM0400W1930886 It' Philips CAR 400 90 532 621 WA029819 I appreciate any help. Thanks Rafi |
Jokerrr Unregistered guest | How does that Calculator works?Has anyone downloaded it? Does it really works? |
Unregistered guest | An other one? I've just put it back before solding it tomorow afternoon... but I had never had this f...ing code from Renault!!!!! So, I'm searching for RN593FV4127888 code Philips 22DC593/62L very very big thanx |
barney gumble Unregistered guest | Hi has any one got a serial number for a phillips audio 4030 sn. phapbfv9102007 many thanks |
New member Username: MaristezPost Number: 1 Registered: Oct-05 | please Can anyone let me know about an code for radio Philips car 400 GM0400V1541813 |
Anonymous | Hi , How can I input code when on display is message 7 CODE after I press AS and switch on radio. Can anyone help me what I must do ?? THX |
Anonymous | ould i have a code for a Philips car 400 please No.90532621 BarCode 1 : 9022 213 96752 01 BarCode 2: 003 9728 1674631 GM0400V1974631 |
radio-code.co.uk Unregistered guest | I can decode Philips, Grundig, Blaupunkt, Ford, Clarion, Delco.. YES DELCO CDR 500.. All instantly, no waiting days for a code, instant via my site with 100% money back guarantee. www.radio-code.co.uk |
Unregistered guest | needto decode my car radio. phillips sc201 |
Unregistered guest | i changed my opel corsa's car battery and cant decode it its a phillips sc 201 |
Tante heiter Unregistered guest | German User use http://stsboard.de |
Anonymous | Hi, Does anyone know the code for a Clarion Finish Line 540 Radio cassette player? Its in a K - reg Mazda 323F and the code is long gone. Any help would be greatly appreciated. Thanks in advance, Best Regards Anis |
Unregistered guest | hi my friend as just brought a stereo off someone and im trying to get the code for him if u can help then that would be great.....its for a car400....the only code i have is 90462560 thanks in advance if u can help |
NEED CODE PLEASE Unregistered guest | hi philips radio from laguna serial RN9B2FS1013664 MY DAD DISCONNECTED THE BATTERY DONT HAVE THE CODE WOULD BE VERY GRATEFULL IF ANYONE COULD HELP WITH THE RADIO CODE THANX DAZ |
Unregistered guest | Please Please Please can anybody help me. Does anybody know the seucrity code for a Delco Electronics CDR 500. My battery went dead the other day and locked the stereo with my CD inside and now I'm lost without my music. I'm talking to myself in traffic. If anyone can save me from insanity and give any tips or codes to solve my problem I'd really apprciate it... Thank you |
soks Unregistered guest | hi i have lost the code for my car radio and now need it again since attempting a refit! its in a fiat punto and the radio just says fiat though im guessing its a philips by its serial number: PHF011V4015497- Stamped on the side. ive wasted money on programmes that dont work - can anyone help!!!! there are other nos on white label:22DC449/64L 9022 214 49644 M/ch 015345 |
Unregistered guest | Hi guys,Please i have need yours help,i need the password por a Blaupunkt rds,serial no ptn 90336222021 Thank you vvv much |
New member Username: ElbartMagliano alpi, Italia Post Number: 1 Registered: Jan-06 | ho un autoradio philips dc247 ...ho perso i codici di aviamento sono disperato non posso gia buttarla via aiutatemi!!!!!!! |
Denys G Froehich Unregistered guest | Any Vauxhall dealer will help with this (for a fee) if you can prove ownership |
New member Username: Marco_pearsonPost Number: 2 Registered: Jan-06 | Hi, I'm looking for a Philips car stereo code please. I'd be really grateful for some advice - my friend has taken it out of her car and given it to me but with no code!! The model no is 22RC200/65 Prod no FD1002249382236 and there's another number: PHAPKF29382236 Can anyone help me please? |
Stuck Unregistered guest | I have the code for my Philips SC 201 radio, but don't know how to enter it in! Does anyone have the instructions? The radio came out of a Vauxhall Corsa if that helps! Thanks. |
Unregistered guest | Please help! I need a code for my cass vauxhall (opel) Philips Car 400 ( model: GM 90506173, PA6-GF15, 1614438 Philips). grieveshane@hotmail.com if anyone know the code ! Thanks |
Unregistered guest | Please help! I need a code for my cass vauxhall (opel) Philips Car 400 ( model: GM 90506173, PA6-GF15, 1614438 Philips). grieveshane@hotmail.com if anyone know the code and access instructions too ! Thanks |
cat11 Unregistered guest | Hi i need code for philips car 400 (opel) serial number: gm0400x2569942 I can't find any solution anywhere, please help me! cat11@poczta.onet.pl |
Unregistered guest | i have a vauhall vectra 2001 make and need a code to work the cd player only code i have is GM 24465993 |
New member Username: FuzziPost Number: 1 Registered: Feb-06 | I need pls code for siemens PA6-GF15 GM 13 107 918 , i change a battery and i cant decode it can you help me??? Thanks |
Unregistered guest | Blazej The serial number is engraved into the side of the radio not on the removable panel. It will be 14 digits long i.e GM0400Y1234567 I can decode most of these via my website or you can send them in for decoding. See my site for info and fees. |
New member Username: SirmadaPost Number: 1 Registered: Apr-06 | Hello!! Need code for my Philips Car 400 Serial nr: GM 040011268112 No.: 90512304 Thanks |
New member Username: SirmadaPost Number: 2 Registered: Apr-06 | Hello!! Need code for my Philips Car 400 Serial nr: GM 0400T1268112 No.: 90512304 Thanks |
New member Username: VgrobbenPost Number: 1 Registered: May-06 | Hi I'm looking for the code for my philips car400. GM0400W2055404. Thanks |
New member Username: Markfa1Post Number: 1 Registered: May-06 | Hi I am looking for the code for a philips car 400 cassette player. Serial number : 9022 213 96752 03 if you need any further info. email me please Plus need to know how to insert the code |
New member Username: VollgaWorms, Rheinland-Pfalz Germany Post Number: 1 Registered: May-06 | I bought an Opel Corsa B last week with a philips SC-201 car stereo radio, but without any code. Have anyone a program to find the number? Here are radio`s data: Philips No: 90 381 124 Type SC 201 (C) W1B Barcode 1: 9022 214 60758 02 Barcode 2: 003 9503 1601075 Thanx a lot for your help! |
New member Username: VollgaWorms, Rheinland-Pfalz Germany Post Number: 2 Registered: May-06 | Sorry, GM-Number is GM0201S1601075 |
New member Username: MuxxaPost Number: 1 Registered: May-06 | I have a Phillips DC 349/1 PA. I disconected the battery to do a maintenance in the car. I made a mistake when I put the code, And now an Err message is appear in the Display. Please, somebody know how can I do to put the code again?. Thanks. |
New member Username: MuxxaPost Number: 2 Registered: May-06 | sorry, my e-mail is maxib@planex.com.ar |
New member Username: Markfa1Post Number: 2 Registered: May-06 | I would like to thank members sending me emails about my phillips car 400 radio. I have now got the code from a source on the web. Code was 4558 thanks again |
New member Username: BjainPost Number: 1 Registered: May-06 | I have recently bought a N reg Rover 214SLI 4 door saloon car. The car was unsed for last 7 months and battery was dead. The radio therefore, branded ROVER, asks for code with orange dispaly showing -C-. Can someone suggest a number I need to enter. It is a 4 digit number. The previous owner did not have the card which had radio code and also immobiliser code. Here are the details of the radio/cassette. Type 22 DC652/60E RG part no. XQD 10056 FD 01 94 50 2477431 Serial number on metal work RG 652FR2477431 Made by Philips but branded ROVER. I can prove ownership of the car if someone needs to know that. Please reply to bjain@rocketmail.com |
New member Username: Nukem_bbsPost Number: 1 Registered: May-06 | Hi there! Please, help me to find the code for Philips Radio in my Peugeut 406. This is what can be found on it: 96 336 890 2L 00 PHI1091327 model no: 22DC594/65B piod no: FD 0299041091327 6/00950/19060/A DM 25-6-1985 DM 27-8-1987 and on the side: PHAPIFX1091327 makes any sence? Cheers! |
Bronze Member Username: RadiocodesPost Number: 18 Registered: May-06 | ENGLISH : http://www.radio-code.co.uk/?lang=eng GERMAN : http://www.radio-code.co.uk/?lang=de |
New member Username: HoudaniiPost Number: 1 Registered: Jun-06 | Hi there! help me to find the code for Philips car400 Radio This is what can be found on it: 90 532 621 2F3 GM0400W2087917 and thaks for help |
Bronze Member Username: RadiocodesPost Number: 25 Registered: May-06 | INSTANT ONLINE RADIO CODES 24 /7 ENGLISH : http://www.radio-code.eu/?lang=eng GERMAN : http://www.radio-code.eu/?lang=de FRENCH : http://www.radio-code.eu/?lang=fr |
New member Username: GartdesignKikinda, Kikinda Serbia Post Number: 3 Registered: Jun-06 | I NEED A CAR CODE FOR PHILIPS CAR 400 GMGM0400W1958338 PLEASE HELP, THANKS BRANISLAV OFFICE@GART.CO.YU |
New member Username: WilliemanPR USA Post Number: 4 Registered: Jun-06 | . |
New member Username: LesternaylorLeicester, Uk England Post Number: 1 Registered: Jun-06 | hi need a code for phillips car 400 no.90532621 Type. Car 400 Other No's 90222139675204 00399072242437 |
New member Username: DmcnanPost Number: 1 Registered: Jul-06 | I need the code for a Philips 400 car radio. It is a second hand car and I do not have the code number. The numbers on the back are 1 614 438, GM 90 506 173, and PA6 GF15. Any help is appreciated. |
New member Username: BenboiPost Number: 1 Registered: Jul-06 | need a code for a phillips car 400 , the serial number is gm0400x2266331 theres another number which is 90532621 anyone can help it would be much appreciated |
New member Username: AcdcadaptorPost Number: 1 Registered: Aug-06 | philips car 400 code need serial: gm0400x2484946 |
New member Username: PirxPost Number: 1 Registered: Sep-06 | Hello I have a question about code to the radio Philips 400 GM 90506 173, >PA6 - GF15< (1 614438) from Rover. Thanks! |
Bronze Member Username: RadiocodesPost Number: 65 Registered: May-06 | Codes available online and can be sent by sms to your mobile instantly from www.radio-code.co.uk |
New member Username: PaweljurPost Number: 1 Registered: Oct-06 | need a code for a phillips car 400. It is a second hand car and I do not have the code number. The serial number is GM0400T1252331 theres another number which is 90462560 anyone can help it would be much appreciated Pawel paweljur@wp.pl |
New member Username: NifletticaPost Number: 1 Registered: Oct-06 | Have found a copy of CAR 400 Radio by Phili[s onlione at: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem%26item=180038809628 it tells you stuff like howto put in your code, adjust security etc hope this helps |
Bronze Member Username: RadiocodesPost Number: 67 Registered: May-06 | Why buy that info ?? Its available FREE on my website : www.radio-code.co.uk Click below for instructions : http://www.radio-code.co.uk/post_in_radio_code_model_selection.php?m=Philips ------------------------------------------------ Have found a copy of CAR 400 Radio by Phili[s onlione at: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem%26item%3D180038809628 it tells you stuff like howto put in your code, adjust security etc |
New member Username: AmitsbPost Number: 1 Registered: Oct-06 | Bought 2nd hand Clio but with flat battery and its asking for the code, I pulled out the radio and the serial numbers are as follows Model No: 22DC259/62F Serial No: RN259FY0244021 Your help in finding the code is much appreciated... Thanks in advance Amit abhawalkar@hotmail.com |
New member Username: UkbigdPost Number: 1 Registered: Oct-06 | Roki. Try This, Let Me Know If It Works. 6ca8 hit OK Code = 1234 |
Bronze Member Username: RadiocodesPost Number: 69 Registered: May-06 | Roki. Try This, Let Me Know If It Works. 6ca8 hit OK Code = 1234 Hi David.. I think Roki wanted the code from serial not by reprogramming the eeprom. |
New member Username: SzylwiusPost Number: 1 Registered: Nov-06 | Hi! I would really appreciate it if somebody could find me a code for a Blaupunkt radio (Opel Corsa), the type is Car 300 (D), and the no. is 90 532 620 (on the bottom there is also a specification 2F2). Thanks in advance! |
New member Username: TripoleLibya Post Number: 1 Registered: Dec-06 | Dear Sirs, I'm looking for code for my Philips CAR 400 for Opel Astra /1999. The number on the case is GM 90 506 173 <pa6-gf15> (1 614 438 PHILIPS) and no. 90532621 type car 400 2F3 Made in Germany Can you help me ,please ?? Thanks & Best Regards, |
New member Username: TripoleLibya Post Number: 2 Registered: Dec-06 | please what happened to my request? thanks |
Bronze Member Username: RadiocodesPost Number: 81 Registered: May-06 | This forum isnt ACTIVE, and requests for free codes are not being actioned by me.... http://www.car-audio-accessories.co.uk |
New member Username: LornaallanPost Number: 1 Registered: Jan-07 | Hiya there, I am desperately trying to find the code for a Philips Car 400 stereo. The serial number is GM0400X2426407, the car is a Vauxhall Astra. Other numbers on the radio are 90222139675204 and 00399252426407. Any help greatly appreciated, Thanks, Lorna |
Bronze Member Username: RadiocodesPost Number: 83 Registered: May-06 | Hi Lorna Your radio code is not listed in the early Philips database so unfortunatly you wont get it from any forum. You can either try Vauxhall Direct or, as you are aware we can also obtain it for you. |
New member Username: Zozi80Post Number: 1 Registered: Mar-07 | Hi There, Could you please help me? I need a code to unlock my car radio (Philips 22DC593/62L) The snr is: RN593FT4048779 Thanks in advance geigerzoli@freemail.hu |
New member Username: DeltaonePost Number: 1 Registered: Mar-07 | Hi There! Need a code for my Car 400 heres the gm code: GM 040023295985 |
New member Username: TourolessPost Number: 1 Registered: Apr-07 | hi I need opel vectra code car400 NO 90532621 2F3 GM 90506173 my email touroless@stcable.co.yu thx |
New member Username: Biofa_dfGama, DF Brazil Post Number: 3 Registered: May-07 | hi I need GM vectra (Brazil) code cdr 500 NO GM0500V0009683 GM 93274400 my email biofa_df@yahoo.com.br thx |
New member Username: LadielyMakati, Metro manila Philippines Post Number: 1 Registered: May-07 | hi there!!! can u help me???how can i connect my ipod into philip s car 400 opel astra????is it possile??? pls let me know!!!!! |
New member Username: LadielyMakati, Metro manila Philippines Post Number: 2 Registered: May-07 | hi there!!! can u help me???how can i connect my ipod into philip s car 400 opel astra????is it possible??? pls let me know!!!!! |
New member Username: NowikpPOLAND Post Number: 1 Registered: Jul-07 | please give me code for radio car400 GM 0400x2595751 Thanks toudip@wp.pl |
New member Username: 441Post Number: 1 Registered: Jul-07 | I need some help I bought a car from an old woman and cuz of changing the bat now the carradio ask me for the code, but she never gave it to me It says 401 in the front and DC441AL in the back, the reference number is A5317 and the number carved on the metal is 699983 How can i get the code number without paying? Thanks!!! |
New member Username: Duki2007Suhareke, Kosovo Kosovo Post Number: 1 Registered: Aug-07 | Hi all I have a question to ask... I need a radio code for my Philips car 400 out of a Opel Vectra `99 NO 90532621 Type car 400 I also have a number on back of my radio: WA039842 please help i need it very much!!! d_haziraj@yahoo.com thanks!!! |
New member Username: Duki2007Suhareke, Kosovo Kosovo Post Number: 2 Registered: Aug-07 | Need a code for my Philips Car 400 PLEASEEEE... GM0400W2121046 No: 90532621 90222139675203 00398422121046 d_haziraj@yahoo.com Thanks... |
New member Username: Duki2007Suhareke, Kosovo Kosovo Post Number: 3 Registered: Aug-07 | Need a co de for my Philips Car 400 pleaseeee... GM0400W2121046 No: 90532621 90222139675203 00398422121046 E-mail: d_haziraj@yahoo.com Thanks in advance |
New member Username: KriswPost Number: 1 Registered: Aug-07 | hi need a code for my radio philips DC594 No:RG594FW2196540 many thanks |
New member Username: KriswPost Number: 2 Registered: Aug-07 | my e-mail:kwysocki5@wp.eu |
New member Username: GustjarPost Number: 1 Registered: Aug-07 | hi all. could someone help with what seems, after reading this forum, a common problem. I need the unlock code for a philips car 400 vauxhall please. the numbers on the radio are 24455379,90222139975403,00302283250159,wa030228. any help will be greatfully received. if possible could someone reply to my email triplebben@googlemail.com |
New member Username: AfissePost Number: 1 Registered: Aug-07 | I need the code for Philips car 400, zafira 2001 GM 90506173 PA6-GF15 1614438 Thank you yoann211@aliceadsl.fr |
New member Username: Car400Post Number: 1 Registered: Sep-07 | I have a CAR400 stereo and when got some work done my battery was disconnected and now i have no code can you help? my S/N is GM040013078235 |
