New member Username: Mythos05Post Number: 1 Registered: Aug-12 | I recently bought a Balfour RCD-4 record changer that's been mint in the box since it left the company in the mid 60's. It's meant to be installed into a cabinet console but I'm trying to convert it to a portable unit. The problem is, I'm not sure what the console would have provided it that I now need to provide. I've heard something about a preamp, but i'm not sure what all that does. Basically I could use any advice from those who know what they're doing. Appreciate it! ![]() |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 17339 Registered: May-04 | . Does the tonearm have a phono cartridge installed? If so, can you tell what type of cartidge is installed? |
New member Username: Mythos05Post Number: 2 Registered: Aug-12 | It did not come with a cartridge but I tracked down a supplier who carries the right one for $35. |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 17340 Registered: May-04 | . OK, what cartridge is that? Is it a ceramic or a magnetic cartridge? |
New member Username: Mythos05Post Number: 3 Registered: Aug-12 | I was told it is an AT3400. I've tried looking it up on several sites and can't find any info as to what it's construction is. |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 17345 Registered: May-04 | . Then you have a problem. A magnetic cartridge requires a step up phono pre ampliifer while a ceramic cartridge only requires a circuit to provide RIAA equalization. The type of table you have could use either. Does the cartridge have a flip over stylus? The type that plays 33 with the stylus in one position and 45/78 in the other? Where did you buy the cartridge? Can't they be of some assistance? . |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 17346 Registered: May-04 | . Why don't you try contacting this site; http://www.turntableneedles.com/Ceramic-Cartridges_c_24185.html |
Gold Member Username: SuperjazzyjamesPost Number: 2012 Registered: Oct-10 |
