I am having the darndest time in selecting the correct inwall speakers. The room is 28'x20'.
The walls are 10 feet high with a pitched cieling ending at 15.5 feet. The room has a 9 foot picture window along w/ windowed french doors on the front wall on the each side of the fireplace.
The room joins the kitchen with is open to this room.. This is our main entertainment room.
I've been thinking about Triads, B&W, Sonance, and similar. Can anyone help. The budget is around 2k for the fronts, another 1k for the rears and then the 2 subs.
Will alter if necessary, but I do need some help.
The fronts will be inwall above the french doors which are 8' tall.
Many thanks for your help `
Ray
By the way, I have a sunfire Ultimate to drive the speakers that are selected.
Music is 70% HT is 30% Jazz, Blues, Rock & Roll, and even some electronic music are what we listen too..
