Hi, I have decided on the Marantz SR4400 AMP & DV4300 DVD Player and am now trying to decide on a good match for main speakers.
So far I'm looking at the Monitor Audio B4 set or Polk Audio R50. Any suggestions as to which or other options?
Will the 6ohm MA's be ok through the 8ohm rated Marantz? (I'm a little new to this).
I will be using for all purposes, home theatre and music, although I lean more towards music in the form of electronica and hard rock. Thanks
elitefan
I can say without reservation that as good as the Polks are the Monitors are better and a perfect match with your new Marantz. My local Marantz dealer has Monitors as their main line and boy is that a awesome combo. If your budget allows consider the Monitor Silver series even if you have to settle on smaller speakers. Either Monitor series will be terrific. Buy whichever your budget and taste dictate.
