I have a sony home theatre in a box, reciever and sat/sub combo. Movies sound good but music suffers.
Would upgrading to a new reciever and 2 floorstanders be worthwhile? I would watch movies say 75% and listen to music 25%. Would I miss the surround sound? Its for a bedroom setup.
Also im specifically interested in the Monitor Audio Bronze B4's.
Any advice would be much appreciated.
Cheers.
Jimvm
Would you miss the surround sound? Only you can answer that one.
I've never heard the B4's, but I did audition the B2's which I thought were pretty nice sounding for budget bookshelf speakers. Have you considered building a home theater with the B4's as your starting point. As you are able to save some money, you could add a bronze center and eventually a couple of B2's for surrounds and a sub. I think that would be a fine system for a bedroom HT.
All of the Bronze series speakers, except the center channel, have a nominal impedance of 6 ohms so you should ensure that the receiver you get will have no problem driving them.
