Seeking advice on receiver-speaker set-up
Username: Jonas
I am quite new in audio set-ups. I recently bought a Marantz SR5300, Def-tech's prosub 100TL, and Wharfedale's Diamond 8.3. Please enlighten me on:
1. Center - since I am on a budget, which do you think is best and would match well with my existing Marantz/Deftech Prosub/Wharfedale Diamond 8.3: a)Wharfedale's Diamond Center b) Deftech's Procenter 100 c) Deftech's Procenter C2?
2. Subwoofer - If the crossover is 40hz to 150hz, how can the spec of my Prosub 100TL of as low as 19hz be reached? Is connecting with a y connector to left and right better than using the single LFE connection at the back of the subwoofer?
3. Break-in - Is it true and necessary?
I plan to buy my center speaker on the 30th of the month after which I'll start looking for my surrounds next month...
