MY SONY450ESD AMP IS HAVING PROBLEMS
when my amp is turned on it plays then fades out when u wiggle the wires the sound comes back again. what is the problem?
Username: Edison
Glendale, CA US
Post Number: 429
Should be an easy fix - take it to an electrician and it shouldn't cost you more than $50 at the most.
Username: Kegger
MICHIGAN
Post Number: 1035
unless it's not moving an internal part and it's
just a wire.
try replacing your speakers wires or rca cables.
