I have a 2 mos. old subwoofer but recently I figured out that it is producing a popping sound especially on loud volumes while watching movies. The volume level of the sub is just set to 11 o'clock, what is that popping sound.
- What's wrong with my subwoofer? - is my subwoofer already damaged? - Do I have to return it to the store? - Is it not yet breaked-in?, how long does it take to break-in a subwoofer?
More info needed,,, How is is it connected? Coax, RCA or speaker lines.. Also is it connected via sub out on receiver, what model sub is it, what receiver are you using, what setting do you have set for sub with receiver ect...
i had the same problem and the solution was so ridiculous. I had not removed the protective cardboard at the bottom of the subwoofer. The cardboard was covering the speaker cone -- Hope this helps
