Need help with power amp/preamp
Username: Rckhrdace
Im trying to hook up a power amp and was told i need a pre amp,they are expensive new and i cant find much used.I was told u can use a receiver if it has pre outs on the back,what kind of pre outs do they have to be? Th e only one i have is a preout for a subwoofer,its a single output,can u use this preout to go to the power amp or no?
Username: Jan_b_vigne
Dallas, TX
Post Number: 16548
No, it is only outputting extreme low frequencies. A "pre amp out" is labeled as that. Typically it is accompanied by a "main amp in" but not always.
Username: Rckhrdace
ok thats what i figured but wasnt sure,ive always had component syatems but the amp/receiver was the same unit,thanks
Need to Register?
Forgot Password?
Enable HTML code in message
