Amp. fuse burn out...
Username: Rockross
Las Vegas, Nevada Usa
blaupunkt pa1250 amp. while flashing after burn out fuse.. what is cause by ? can fix it ? please help me... thanks..
learn english.
Username: Audiophiliac
Boise, ID USA baby
Post Number: 11
as Larry The Cable Guy so politically correctly puts it in holiday song and verse for us,
"Oh come all ye immigrants. Come and get your green cards. Come learn some english and then how to drive."
MRsteve
not sure either of you helped him........maybe the two of you could help him? Start by showing him not put capitals at the start of his sentences, this can only aid his lack of English??
Take this how its meant
MRsteve
Username: Adstark
MPLS, MN
How about all of you quit being jerks, and offer the guy some real advice or none at all.
It sounds as if you have a ground issue I would check all your wires first. make sure the power and ground wires are not touching at all. If this doesn't work check to see if the fuse in the amp is the correct size. this is just a starting point for you.
By the way Kevin, it would help you more if you posted your question in the car audio forum.
Good luck
MRsteve
good call adstark...
MRsteve
