Need some help - NAD 1700 and NAD 2700 THX
Username: Markfsanderson
Tomball, TX USA
After a couple of years out of the A/V hobby, I've made a few purchases of new and used equipment.
NAD C541 CD Player
NAD 1700 Pre-Amp
NAD 2700 THX Power Amp
Mirage Omni 60 Book Shelf Speakers (I ran into a great deal - couldn't resist $200/pr @ Tweeters)
PSB Image 4t
Vampire I/C
So far so good . . . everything works as I hoped and I love the sound. Problem is that I don't have manuals for either the 2700 or 1700. The 1700 in particular has something in the front called 'EPC' or something like that - and they coresponding outputs in the back via RCA jacks(is this for driving sub-woofers?) Any info on this would be appreciated! Also, does the 1700 have the facilities to do bi-amping? Right now I only have the 2700 hooked up to my speakers. Any help on locating a manual and/or help here would be greatly appreciated!
Thanks!
Mark F. Sanderson
Username: Kegger
MICHIGAN
Post Number: 946
have you tried the nad website most of the time you can
download the manuals in a pdf format to be read by
acrobat reader "adobe"
Marco van den Hout
EPL is for external processor loop, for example to hook up an external equalizer. You can also connect a line level device (cd-player) to the EPL inputs and when you press the EPL button on the front you will hear the sound from that device.
