I own the Audiovector S3 Signature speakers with the Moon i1 amp + i1 cd player.
I think the weakest link is the i1 amp, sometimes I feel the amp cannot handle my speakers, at louder passages the sound becomes little harsh and uncontrolled.
Could anyone give me an advice what amp will sound nice on my S3 signatures and moon 1 cd player?
Frequency Response 6dB : 29-26 kHz Sensitivity : 91 dB Nominal Impedence : 8 Ohms Frequency Filter :420/3000 Power Handling: 275 Dimensions (HxWxD) in cm : 103x19x33 Weight 21 Kg
Gee, what a tremendous help that was. There are no "S3" speakers listed. There is a "Si 3 Signature". Is that what you own?
If so, the webpage appears to offer no technical information about the speakers, not even a nominal impedance or a sensitivity spec. I'll take your word for what you've provided but you need to know the lowest/highest impedance point, the frequency or frequencies where they occur and the electrical phase angle of the system at that same frequency or the highest phase angle the speaker hits. Without information, there's no way to help you make a technically good decision about amplifiers. Why don't you try the manufacturer's own forum?
