ok i have two sony 12 inch subs i know they are brutal but im buying 2 10inch earthquake subs with a 1900watt amp and the amp is 450$ and the subs are 600$ for both of them. Im thinking of putting all 4 subs in one box with this amp will this work??? thanks
Ed Sullivan
putting 4 woofers into one enclosure can incure problems with sound because an idealy sized box for thos drivers with out know the thiele samll parameters of the drivers would probably be something 20+ cubic feet ported i would suggest seperate enclosure but then agian i am going on the idea this is for home use
no this is for my car what should i do with these sony subs i really want to get all of them hooked up and the only way i can do this is in serperate enclosures ??? please help me out this is going to be my first system
Ed Sullivan
for a car you shold be able to make an enclosure for the 4 drivers in a sealed box if you have the room go for the thiele small parameters and figure out what a sealed box would take but if not id go for something a around 8 cubes or 6 cubes of enclosure and remeber the samaller th enclosure the boomoy its going to sound and hampers performance
yeah so it wont wreck or anything will it?? i already have the two 12"s in the box and im planning on puttin the two tens on top of the box. how would i run this i have a 1900 watt amp could this power all of them? or would i have to get more
