What sub do you suggeat?
Username: Psbnadfan
I have a system that starts with an NAD 762. The front L/R are Stratus Silver, the center is a C6i, and the surrounds are Mini Monitor. I am thinking I should go for the C6 sub to match the system but am wondering if there is another, that would fit just as well that may be better.
dwsw
How much do you want to spend? With subs, it is not as important to match brands as it is matching your front,center&surrounds. With subs you should shop around...and go after the sound impact you want, not the looks, or whether the name tags match. Best of luck.
Username: Psbnadfan
I am willing tospend as much as $600... I hav come across a deal for the PSB C6 at DMC-electronics... any other suggestions?
