Totem Dreamcatcher + Creek Evolution Amp: a good combination?
Username: Blacknile
Hi,
I was wondering if any of you has tried the above combination or a similar one and would like to comment.
I'd be interested in your opinions on the Totem speakers in general, as well.
Thanks a lot.
Username: Hawkbilly
Nova Scotia Canada
Post Number: 1364
Totem speakers are highly respected brand.....but each model in their lineup has its own sound. You have to find the one that suits you best....perhaps for you that's the Dreamcatcher. I've not heard the Totem models matched with Creek amplifiers so I can't provide any specific feedback. The power supplies in the Creeks tend to be pretty robust, so I wouldn't think there would be an issue sucessfully driving the Dreamcatchers, but how they sound together I couldn't say.
Username: Blacknile
Thanks...the manual on my Creek says it outputs 170W in 4ohm. The Totem Dreamcatcher has the following specifications:
87.5 dB/W/m. Maximum SPL 101 dB before dynamic compression
Do these specs mean the Creek is theoretically capable of driving the Totems?
Username: Hawkbilly
Nova Scotia Canada
Post Number: 1365
The Creek will drive them just fine.
