Optical connection between McIntosh MX132 and Krell Showcase DVD
Username: Omggb
Hi experts,
I've been trying to use Krell Showcases DVD for a CD player. I connected it to McIntosh MX132 using an optical cable. I used the top slot (CD) on the leftend of the back panel of MX132 and I don't hear anything. It is in Zone A. Is there anything I need to check or set up first? Or, is there any better connection for a good sound? Any suggestion will be appreciated. Thanks in advance, you guys!
Username: Jan_b_vigne
Dallas, TX
Post Number: 16251
You probably need to go into the set up menus on both components and switch "on" the optical in/outs. If that doesn't do the job, don't you have a deler from which you purchased one of these components who can provide some after the sale assistance?
Username: Hawkbilly
Nova Scotia Canada
Post Number: 1331
The DVD player may not be streaming PCM as well. You'll need to check the configuration menus of both components.
