How Do I Cut .mts Files
Username: Sylvanas1147
Can anyone shed light on how to load and cut an .mts project? Thank you.I am using Panasonic HDC-TM900 and similar cameras -- all Panasonic.
Username: Laurelsweet
What is the OS you are running?
For Windows, you can use the bundled HD Writer AE to trim .mts files. If you would like to split mts file, try tsmuxer.
For Mac, iMovie will load the 1080i videos from TM900, but not the 1080/60p videos. Try final mate for mac to cut mts footage with timeline.
Username: Coldwilson2011
Searching on the net, you will find many such editing softwares.What you shouid do is to choose a better one . Final mate is pretty good.I am now using it ,you can have a try .}}
Username: Jamesbond1234
Please refer to the page of our Smart Cutter for more information. When you need to process your AVCHD Camcorder movies, you may have it a try.
Now do not hesitate to try our Smart Cutter, the easiest way to split native MTS clips without re-encoding, or merge them into one file without conversion.
Need to Register?
Forgot Password?
Enable HTML code in message
