Problem with receiver. Amp won't "click" on power up.
Hi all.
I have an old Denon DRA-625RA Receiver. It's been a great receiver, but recently it will no longer power up the power amp. When I turn on the unit, everything powers up and appears to work normal. The EQ shows a signal and all. Normally, when you first power the unit there would be like a warm-up delay and then a noticable "click" when the unit was ready. For some reason, the "click" never happens so I get no power for sound.
Any ideas? Is it just dead?
Nothing odd every happened, it just stopped working one day.
hi, i am having a problem with my Denon DRA-625RA,while playing,the volume/the sound level will drop well below the level it was playing at.at times i have to tap on the receiver to get the volume back
