Digital to analog 5.1 outout?
Hi,
I have a home theater with no digital inputs! I would like to connect it to my DVD player that has a Digital output COAXIAL or to my Xbox (OPTICAL) Is there any way i can convert Digital to analog? (2x front, 2x rear and 2x center)
Thanks!
Username: Landroval
Post Number: 353
Yes, you will need an additional decoder wich will convert a digital DD/DTS stream to analog format.
The Creative DDTS-100 is the best choice for you:
http://gear.ign.com/articles/449/449167p1.html?fromint=1
http://www.tomshardware.com/consumer/20040120/index.html
