Yamaha RXV640 vs Onkyo TX-SR601
pcl
Just purchased 42" Grand Wega LCD rear projection TV and am upgrading receiver. Any suggestions on which of the 2 is best. Each sls person says theirs is better. Help...
Username: Landroval
Post Number: 352
I think neither is very good, there are better options available. From those two I would take the Onkyo.
Username: Pattie
Fountain HIlls, AZ USA
Am looking to spend max $500 - what other receivers do you suggest.
Depends! What brand of speakers are you planning to use with the receiver? Is 6 channel a must? How large is your room?
Username: Zyepod
GA USA
I've got both Onkyo 595 (I think) and a Yamaha 650 which I going to up-grade to the 1400. In my opinion the Yamaha sounds and out performs the Onkyo. To me you get more bang for the buck with the Yamaha. One of the first things I noticed was the volume control was much better with the Yamaha, and many more surround fields to play in.
