Bose 161 as rear speakers..
Folks,
have a HK330 paired up with Paradgim Monitor 7s. I am thiking of CC370 for the center and the bose 161 for the rears. (wanted to use ADP-370 .. but they are too big for the space that i have). Any users of 161 as the rear.. can you comment on how well it sounds..
Username: Elitefan1
Post Number: 487
Please do not ruin an otherwise nice system by using any Bose speakers anywhere. If you have a space problem use the Paradigm Atom for your surrounds. They are only 10 1/2 inches tall and will work just fine with the Monitor 7. By all means get the cc-370 asap. One of the great things about Paradigm is you can mix and match most of their speakers even in different lines and they work just fine.
