HELP - Is my amp knackered? ARCAM 8+8P
mike wilson
Hi,
I have a bi-amp system using an arcam alpha 8 and an 8P power amp and KEF speakers. It was working OK before I moved house but now after I hooked it all up again in the new place the power amp makes a horrendous noise at max volume and I have to switch it off again. This is probably an obvious question but what could be causing this? Is it simply broken or is there something obvious I can try? And if it is busted, is there a guide somewhere that explains how I can rewire my bi-wire speakers with just the one amp?
cheers
mike
J. Vigne
The amp needs to be serviced. There should be directions in the owner's manual for your speakers on how to uni-wire your speakers. + to + and - to -.
Username: Giga
arcam have the best customer support in the industry... they'll fix your amp at little cost...
biwiring nearly always sounds wrong anyway... just connect a bit of cable to both positives and another to both negatives and bobs yer auntie - single wired speakers.
