Enclosure for sub and how to move air?
Username: Jodavis
Toronto, Ontario Canada
Post Number: 31
Hello,
I want to get a pair of new subs, 15" 2,000wrms Orion HCCA's for my bedroom. My enclosure is going to be a dual-sub ported enclosure (obviously lol) but the thing is that I don't want to build my own box as it's too complicated nor do I want the manufactures box. What would happen if I order a random but well bult custom made enclosure? And, will a ported box alone move enough air? I want my american flag to wave....then fall down.
Username: Jan_b_vigne
Dallas, TX
Post Number: 16064
You can't just stick a driver in a generic box and expect good results. The enclosure must be tuned to the needs of the driver for best results which means either a custom built box or a generic box with lots of latitude in how you complete the system. Even with a generic box, the port must be tuned to provide good bass extension without flabbiness. This box/port tuning provides the proper twin impedance peaks which are the goal for any simple vented system. There's no way to manage this without some effort.
Need to Register?
Forgot Password?
Enable HTML code in message
