Multichannel integrated amps
zootopia
are these types of amps available? i would like to use it as part of a home theater set-up. what manufacturers should i look for? appreciate any info.
Username: Billdashill
Post Number: 14
Yes, they're out there. If you have DAC's and a tuner (if you want) you'll be set. I am still keeping that as a possibility for my setup. I even found some 5 channel integrated amps with onboard DAC's for A/V. Not many though and most are out of production. One was a Nakamichi and the other was a Rotel. Both, out of production.
