New member Username: SnipesacePost Number: 1 Registered: Dec-10 | Hi, I have a Dual 1273 and am just looking for some information about it. Years ago I dug it up out of basement. It is my father's, I believe he got it 1977 (at least, the owner's manual is from 1977). about 5 years ago I took it to Columbus Radio in Winnipeg to be tuned up, and the gentleman there offered to buy it for around $800, which seemed pretty steep to me. I have not been able to find any sort of information on this particular model, anyone know anything about it? |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 15679 Registered: May-04 | . I sold Dual for more than a fifteen years and I don't remember that model number. In the late '70's Dual had switched from the "12" series tables which were changer/single play models to the "500/600/700" series. There's no reference to your model number on the "Dual reference" site; http://www.dual-reference.com/tableinx.htm . |
Gold Member Username: MagfanUSA Post Number: 1965 Registered: Oct-07 | I had a Dual 1209.....maybe '71 or '72? The neat feature was the center 'umbrella' which was the gate for 'stacking' records. To make a record play over-and-over...you put the 45 center on the spindle and a record on top. It would continue to play the same record until stopped. This TT was even good enough to take advantage of a much better than regular pickering / empire / shure cart of the day...in the form of an Ortofon LM20 which was the finest cart I ever owned. bar none. Like buying an all-new record collection. As for the 1273? Euro only model? In any event, if real, it was pretty late in the series. |
Gold Member Username: MagfanUSA Post Number: 1966 Registered: Oct-07 | Mis-write for 1237? Bet I'm correct! |
Platinum Member Username: NuckPost Number: 15648 Registered: Dec-04 | http://www.dual-reference.com/tables/1237.htm This one? |
