Interconnects for new CDP
Username: Tpizzle
Post Number: 579
I have an Emotiva CDP on the way and in the meantime I thought I would look into upgrading interconnects. Currently the CDP will run through a reciever but in the near future I will be upgrading to an integrated (likely a Cambridge Audio). What connection would you guys recommend for this and any certain brands/models?
Thanks
Username: Magfan
Post Number: 1942
Try to take advantage of the balanced outs......The noise rejection alone makes it worthwhile.
IF the player is truly balanced.
Does the CA amp you have in mind have balanced 'in's? As near as I can figure, only the '8' series has balanced available.
Good cables don't have to break the bank, either.
Username: Nuck
Post Number: 15633
Bluejeanscables
Cheap, clean, good quality,frlexibility(important) and repeatable terminations.
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 4610
I was a big fan of BJC for a long time, well still am, actually. For the money they're good cables. But when Nuck lent me a pair of Cardas cables.... BAM. Immediate difference - noticeable increase in the amount of bass.
Username: Magfan
Post Number: 2028
If you go balanced, try Mogami. Inexpensive and available OTC at the local Guitar Center.
The difference between the Mogami and the 'as issued' cable was enough to make it all worth while.
Need to Register?
Forgot Password?
Enable HTML code in message
