I am running axiom m22ti's 1 SVS 25-31PC+ sub and i want to get comparable surround sound speakers. (in the proccess of aquiring reciever) to those that have not heard m22ti's they are unbelievably great (400 dollars only), but some say they have a slight personal touch too them in the mids.
Would i be best off with axiom surrounds, or are there other great surround speakers that will mix and match easily.
all suggestions welcome
it might be good to go with the surround sound speakers from the same company, as it might have same color tune differences
i am also looking for a surround sound set of speakers
i have heard paradigm are good, but dont know
not too many proffesional reviews on surround sound speakers
Hawk
Hawkson:
Given the reasonable price of the Axioms, I would recommend a pair of the M2s as they would be a close match to the sound of your M22ti mains. Remember, surrounds do not need to go low into the bass like the mains do.
Anon:
What do you have now for your amp and your main speakers? Also, what size room do you have? If I know this, I can suggest some appropriate surround speakers for you.
