Help with technical specifications
Username: Derrtel
Post Number: 14
Hi,
I've been looking at several speakers lately, getting to know what's on the market before going to dealerships but I have problems understanding what is called nominal impedance (the ohms thing). Could someone explain me?
I know we're talking about an electrical resistance here, but I have no idea if this has to do with power input/output, power consumption, ...?
Should you "have" as much ohms as possible or as less as you can?
Thanks
(sorry for the bad english)
Username: Superjazzyjames
Post Number: 484
8 ohms is the standard impedence for home speakers. Most home amps (receivers, integrated amps and seperate power amps) are designed for 8 ohm speakers. Unless you want a very long high tech explanation by me or someone else, it's best to buy a pair of 8 ohm speakers. Frequency range and sensitivity/efficiency are the only really meaningful specs.
Username: Kbear
Post Number: 848
https://www.ecoustics.com/electronics/forum/home-audio/643339.html
This thread should help. The impedance (measured in Ohms) of a speaker can vary wildly, and it's never a constant. So when a company says 8 Ohms or 6 Ohms nominal, it generally means little.
Check out some Stereophile reviews, as they post speaker measurements. You can see just how much impedance varies, and their comments (while often tough to understand) are helpful. Also, the Symphony Sound article linked in the thread I provided above is a must read.
Username: Derrtel
Post Number: 15
Thank you guys. I read the thread you linked and it was very helpful.
I think I get it now!
Username: Nuck
Post Number: 15592
That's it?!? We don't get to redo it? Darn.
Let us know how you do, Derik?
Username: Magfan
Post Number: 1895
Too easy?
Username: Nency
Post Number: 99
Typical values for the nominal impedance of loudspeakers are 4, 8, 15 and 16 ohms (ohms are the standard unit of resistance). Four-ohm loudspeakers are normally battery-powered or found in automobiles, while 16-ohm loudspeakers are usually of the older, "valve" type, according to Hugh Robjohns, in the "Understanding Impedance Workshop.
Post Number: 701
I never heard of a 15 ohm speaker. 16 ohmers went out with the covered wagon. 4 ohms are standard for cars, 8 ohm are standard for home. There are a number of 6 ohm spkrs on the market for home use, but I'd recommend sticking with 8. Your amp probably won't like 6 ohms very much.
Username: Magfan
Post Number: 1919
I'd love to see someone get my 4ohm panels in a car.
And, BTW, I've had 2 different models of 'em in the last 30yrs or so.
Post Number: 703
Again Leo, I'm talkin standards here. You and your system are the exception.
Post Number: 704
MOST speakers for home use are 8 ohms. SOME are 6 and a rare model or two are 4. MOST speakers for car use are 4 ohms. Anything that Leo has anywhere is the exception to the rule. He's got the only cd player that uses a needle, don't you Leo? Lol!
Username: Magfan
Post Number: 1922
At least I don't find it necessary to keep a CD rewinder around.
Most? perhaps: that just means >50%.
The implication that 4 ohm speakers are unusual is just wrong.
However, the balance may have changed....and continue to favor 8ohm stuff, since most HT receivers are too junky to drive anything but.
That switch on the back of some HT receivers for low(er) impedance loads? Simply a concession by the designers that they make marginal power supplies.
Post Number: 710
ROTFL! That's a VHS tape rewinder! You're too much Leo!
Truth be known, yours are the only home speakers I've heard of that are 4 ohms in at least 20 years.
Post Number: 711
Didn't you notice I said VCR and TAPE rewinder?
Post Number: 714
Personally, I don't think there is anything wrong with 8 ohm speakers.
Username: Jan_b_vigne
Dallas, TX
Post Number: 15632
Post Number: 719
Jan, in accessories I made a post regarding the "green power" feature in some of Monster's surge protectors. The model I have has 8 outlets. One can be used to shut 3 others off. When my receiver is in standby, the sub, dvd player and TV get no power at all. The other 4 are unswitched. I mentioned the vhs tape rewinder being plugged into one of these unswitched outlets.
Username: Magfan
Post Number: 1926
VCR? TAPE? In that thread I thought you were having a retro/senior moment and ignored it. Don't you think a tape rewinder powered thru a power conditioner is a little....obsessive?
My crack was a reference to a CD player having a needle....
I keep a VCR to watch my Rocky and Bullwinkle tapes.
I haven't seen a tape rewinder in quite a while. I might have one in the box with my tape head demagnetizer and tape splicing block.
Just my opinion, but the 'green' outlets are just another solution in search of a problem.....
Post Number: 723
You're killing me Leo! Plugging the rewinder into surge protector is convenient. However, it did belong to my late in laws. So protecting it from surges is probably not a bad idea with regards to my wife and sentimental value she has attached to it. It's red and shaped like a sports car and the headlights light up when it's rewinding.
Rocky: Bullwinkle! Your foot!
Bullwinkle: Of course it's my foot Rocky, I've got another one just like it!
Dallas, TX
Post Number: 15635
Post Number: 724
Personally Leo, I like the green power and find it useful. There is no law saying you have to get one YET! I am trying to get such a law passed right now just for you! Just kidding!
Post Number: 730
My stereo cabinet is located near only one pair of outlets. I have the surge protector plugged into one outlet and a lamp in the other. There was only one outlet available for the rewinder, in the surge protector. So it gets protected. I'm sure everyone thinks I escaped from the funny farm by now. The truth is I haven't been there because I haven't been caught yet.
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 4527
"Truth be known, yours are the only home speakers I've heard of that are 4 ohms in at least 20 years."
http://totemacoustic.com/english/hi-fi/compact/mani-2-signature/specifications/
Post Number: 734
I didn't say there weren't others, David. I'm just indicating that 4 ohm in the home are not real common.
Username: Kbear
Post Number: 854
Dynaudio too.
If I had to ballpark it, I'd say 50% are 8 Ohms, 25% are 6 Ohms, and 25% are 4 Ohms. Maybe it's closer to 15% at 4 Ohms, I don't know, but I wouldn't say 4 Ohm speakers are rare. I've come across many.
And as discussed, nominal ratings tell about 1% of the story, so why put much stock into them? Paradigm Studio 20 is rated at 6 or 8 ohms, can't remember which, but what do you know? They actually dip below 4 ohms. So frankly, Paradigm's quoted nominal amount means nothing to me.
Post Number: 738
That's true and funny. Mirage states that omnis have a nominal impedence of 8 ohms and a minimum impedence of 4 ohm. Any guesses as to how accurate that minimum is? I like them, but I never believed that they never dipped below 4, especially at high volumes.
Dallas, TX
Post Number: 15638
Post Number: 747
Jan, what's up with all the ???? Are you okay tonight?
Username: Nuck
Post Number: 15628
James, your posts are coming fast and stupid.
You have no idea how many varieties of speakers come as rated at 4 ohms, which is basically just a warning label?
Receiver salesmen must not advertise these much...
Post Number: 778
No they don't Nuck. Then again, the vast majority of reviews I've read on speakers in ALL price ranges were 8 ohms.
Username: Magfan
Post Number: 1930
HT guys might not look 2x at 4ohm speakers. The guys that sell HT stuff may want 4ohm speakers to disappear....'an inconvenient truth', perhaps.
Real hi-fi stores have 'em all....and let the impedance fall where it may.
And yes, like most specs, treat it as advisory, not Biblical.
Thanks for the help, gentlemen.
I believe Jan is expressing a form of disbelief.
Post Number: 798
When I read speaker reviews, they are always writen by serious audiophiles, NOT HT guys. Hardly ever is 4 ohm speaker mentioned and 6 occasionally, but since impedence is only a nominal or advisory spec anyway, why would it matter?
Username: Dmitchell
Post Number: 4532
It's probably rather meaningless unless you look at the impedance + phase chart for the speaker.
Post Number: 806
Even with the phase chart, how much real meaning is there?
Username: Dmitchell
Post Number: 4534
A lot more useful than just the nominal impedance. It lets me see if the speaker is going to play nice with my tube amp.
Post Number: 807
How many speakers are there on the market that will play nice with a tube amp these days?
Username: Magfan
Post Number: 1932
Between phase and impedance, a judgement, preliminary as it is, about a speakers ability to 'play well' with tube is possible.
A big impedance dip at the same frequency as a huge bump/dip in phase is a red-flag situation.
Super,
Please look up Power Factor for a better look at this info
Also, take a look for 'Smith Chart', a way to represent BOTH phase and impedance with a single line. This display to many is very readable and has all the relevant info about phase/impedance in one package. No double lines.
Dallas, TX
Post Number: 15648
"How many speakers are there on the market that will play nice with a tube amp these days?"
"Even with the phase chart, how much real meaning is there?"
The vacuum tube market is alive and thriving - especially low wattage, single ended tube amps sold exclusively through the internet. They may not be worrying Pioneer but they are an active market keeping dozens of companies in business. Whether a speaker plays well with a tube amp isn't even the point of impedance and phase. Most tube amps are transformer coupled and will match to the nominal impedance of virtually any speaker on the market. But nominal impedance is not the issue, a tube amp's high output impedance will respond to the impedance swing of the speaker's reactive nature resulting in bloated lows or thinned lows, screaching highs or rolled highs, peaked mids or laid back mids or everything as it should be. Knowing the impedance swing vs the nominal impedance tells the user which speakers are suitable for their amplifier. Knowing the phase angle of the reactive component will tell the user whether the speaker requires high current or high voltage - an important consideration when using a tube amp or a low powered (not high current delivery) solid state amp.
In the end, a speaker that is easy to drive is desirable no matter whether the speaker is attached to a tube or a solid state amp. A speaker that does not require a massive power supply and high current delivery will play well with any amplifier. That's "how many" speakers are designed to operate with tube amps - any that are meant to play well with any amplifier, tube or not. If you have a low wattage amplifier or a low current amplifier, say, a budget HT receiver, you want a speaker that can play well with a tube amp.
James, what you claim to have read doesn't seem to be in synch with the real world. I would say you are once again covering your @ss after making a less than factual statement. Four Ohm speakers have been around for ages - The Small Advent designed in the late 1960's was a "four Ohm" speaker as were many of the earlier AR and KHL models all of which had "best selling" models in the 1950-70's. Sixteen Ohm speakers were not that uncommon until solid state arrived and the technology preferred eight Ohm loads. I have a pair of fifteen Ohm speakers which I have used for many years, they were designed in 1976 - twenty years after the introduction of transistors - and they are widely recognized as a model for speakers to follow. Four Ohm speakers are common. Why not just let it go at that? Stop arguing everything you say when a considerable amount of what you say is incorrect.
Dallas, TX
Post Number: 15649
"When I read speaker reviews, they are always writen by serious audiophiles, NOT HT guys."
http://www.avguide.com/channel/the-perfect-vision
http://www.audioholics.com/
http://www.widescreenreview.com/
http://www.electronichouse.com/
C'mon, James, just because you don't know about it, that doesn't mean it doesn't exist. Stop arguing everything.
Post Number: 813
Jan, I asked DAVID a simple question, not you. Otherwise, yes I have read many speaker reviews by serious audiophiles and 4 ohm speakers are rarely mentioned in those reviews.
I really don't care about Advent speakers from the 60s. What's that got to do with here and now? Nothing!
Username: Dmitchell
Post Number: 4535
There's lots James. I have 2 pairs at home that are exceedingly tube friendly. I look out for what Leo mentions:
"A big impedance dip at the same frequency as a huge bump/dip in phase is a red-flag situation."
Post Number: 815
Thank you David. The last time I had tubes was in the 80s. I had very old pair of Scott integrated mono amps, 35 watts each. Sometimes wish I still had them. My grandfather gave them to me. I remember the preamp tubes were either 12AU7 or 12AX7 and the power supply was a 5U4GB. I don't remember the outputs though.
