How can I attach a 3.5mm jack to my old hi-fi system speakers
Username: Neyaz_shafi
I have a pair of speakers from an old AIWA hi-fi system.
The speaker wires connect to the music system as seen in the link below.
http://img14.imag esha ck.us/i/img0319kq.jpg/
Please remove the spaces from the link. The forum was not allowing me to post the link and the picture is relevant to the question.
I want to be able to connect these speakers to a 3.5 mm jack.
Are there converters available in the market for this. If not , then what needs to be done ? Any kind of help would be appreciated. Thanks
Username: Jan_b_vigne
Dallas, TX
Post Number: 15597
From what I can make out, you need to buy a 3.5mm plug. You should be able to find this at a Radio Shack. However, you don't indicate whether you have a RS in your area. Without knowing where you live and what you have access to there's not much to recommend other than you need to find a plug and maybe a cable and go from there. What exactly are you expecting from us? What are you trying to connect to the speakers? You'll need at least a few watts of power to drive the speakers to any kind of volume.
