New member Username: Lawr1Post Number: 1 Registered: Nov-10 | Hi there Looking for parts for my Rotel Sanken S-40W power amp Need to replace them.... Anyone have any or know where to get this? Need to fix my great amp, have had it forever! |
Silver Member Username: SuperjazzyjamesPost Number: 395 Registered: Oct-10 | If this amp is over 20 yrs old or maybe even 15, getting parts for it and the price you could pay might just not be worth all of the trouble. I'd encourage you to try, but at the same time start shopping around for a new amp. It's hard to let go of things that serve us well, but some times, we gotta. |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 15589 Registered: May-04 | . What are you looking for? Some parts, such as pots, caps and resistors are quite generic and can easily be found for most amplifiers produced over the last fifty years. Other parts, such as transistors or ic's might have equivalents which will require you do some cross checking of numbers. Some parts are specific to a manufaturer and once the manufacturer has stopped supporting a product the only way to acquire parts would be to salvage another junker unit. Parts for popular vintage components such as tubed McIntosh, Marantz, Dynaco, etc. are available through specialty shops which do their main business in repair and restoration work. Depending on the issues you wish to resolve you might find yourself going through several resources to complete the job. On occasion a particular part might be temporarily out of stock and not available until a sufficient number of requests have been submitted to make it worth while pulling a limited run of thermistors or such. And, on occassion, a suitable part simply is no longer available. As with any vintage component you need to balance the cost of repairing a problematic component which might just be signalling the beginning of other problems ocurring down the road. Eventually things do wear out and, yes, you can keep them going but, at what point does it become the less wise alternative to just replacing the product? Are you going to do the repairs yourself? Most shops will not work on any component more than a few years out of warranty since they prefer not to be tied down to a component which might have multiple issues which would cause numerous returns to the shop. It's not at all uncommon for a shop to repair a power supply only to have a coupling cap go out a week later and they need to absorb the bench time for an unrelated repair. . |
New member Username: Lawr1Post Number: 3 Registered: Nov-10 | HI Jan I have a shop that specializes in these repairs............. The part I need is an IC 602 and/or IC603 It's listed as a s-40 W power amp they look like two little boxes that attach to the amp i have attached the schematic |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 15595 Registered: May-04 | . Why don't you try this request over at AudioKarma? http://www.audiokarma.org/forums/forumdisplay.php?f=13 You stand a better chance over there. The vintage forum has a few members who do repairs and they might have a source for you. If you run across Kegger, tell him I sent you. If AudioKarma can't help, head to diyAudio.com; http://www.diyaudio.com/forums/ I do tubes for the most part and wouldn't have a good lead for ic's. . . |
Gold Member Username: MagfanUSA Post Number: 1876 Registered: Oct-07 | Custom ic's may be a problem, but discrete is alive and well. ICs in the form of OPAMPS and logic should be available well into the next century. Many of these are 'commodity' devices and are made by many aftermarket guys. I just used a generic OPA2134 in a headphone amp. Just Google 'transistor cross reference' and you will find many sites. NTE semiconductors has a HUGE catalogue / cross reference of transistors, diodes, SCRs, Triacs and all the rest. NTE is not a hi-fi brand, like say....Vishay, which may also source some useful devices, not to mention their thin film resistors. International Rectifier has FREDs and HexFets not to mention IGBT devices. Some IR stuff is used OEM by say.......Sunfire. |
Gold Member Username: MagfanUSA Post Number: 1877 Registered: Oct-07 | http://www.electro-tech-online.com/datasheets-manuals-parts/42162-sanken-s-40w-s -60w-datasheet-found.html datasheet ref for the transistor in question. |
Silver Member Username: SuperjazzyjamesPost Number: 430 Registered: Oct-10 | If you go to all the trouble, I hope it yields lasting results. |
New member Username: Lawr1Post Number: 4 Registered: Nov-10 | Hi All And thanks for all your input Can anyone help me find this, there is a reward! I am not tech savvy, so wouldn't know what part to get to sub in It is a Sanken part , listed in the manual as IC 601 or IC 602 they are little parts that attach to amp itself The part number is 303452169 and listed as s-40w power amp I can send anyone the manual with schematic and part listing I have a pdf Thanks lawrence |
