Moving Coil impedance match.
I have an AT-OC9ML/II which recomends an amplifier loading of 20ohms. My amp's moving coil input has an impedance of 220ohms. Does anyone know what sort of effect this mismatch is likely to have on the sound of the cartridge?
I think it will only require changing two resistors in the moving coil circuit of my amp to rectify the problem but would only consider this if it was worth the effort in terms of sound quality. Please e-mail me if you have any suggestions at Rickdomino47@aol.com Many thanks.
