I just bought a used Sanyo turntable TP-1020 and the volume on my receiver is turned all the way up ,and I don't get any volume increase it is very low. does anyone have any ideas on how to fix this ? THANKS !
Check the archives of this section of the forum for your answer. You need to step up the phono level. Common problem, the answer's always the same and you'll find links to where to buy the step up device.
