New member Username: Paikens09Post Number: 1 Registered: Oct-10 | i have the bose am9p subwoofer i bought it it worked great my power cord had a fray in it now the sub wont work not sure if there is an eternal fuse or what else could be wrong thanks |
Platinum Member Username: PlymouthCanada Post Number: 15289 Registered: Jan-08 | Joe Test your Power cord or replace it! |
New member Username: Paikens09Post Number: 2 Registered: Oct-10 | i tryed a brand new one no luck any other ideas or does anyone know if it has a internal fuse or how to open it up without breaking it? |
Platinum Member Username: PlymouthCanada Post Number: 15291 Registered: Jan-08 | Yes there is a internal fuse! http://myboserepair.com/acoustimass%20dissassembly.htm http://elektrotanya.com/PREVIEWS/63463243/23432455/bose/bose_amp9l-cs6-ls6-am25p .pdf_1.png |
New member Username: Paikens09Post Number: 3 Registered: Oct-10 | do you know where the fuse is located or round about whereshould i look so i only go as far as i have to also do you fix these? thanks for all your help |
Platinum Member Username: PlymouthCanada Post Number: 15309 Registered: Jan-08 | Sorry Joe but I don't know your sub! You can send a mail or call the expert of Bose at this site: http://myboserepair.com/acoustimass%20dissassembly.htm |
