NHT SW2 sub-which amp?
Username: Jfuta
I recently came into a NHT SW2 passive subwoofer. I have a new Denon AVR 391 receiver which my speakers are currently hooked up to. Now I know that the NHT SW2 can't hook up directly to the receiver, but I was wondering what specific amp I should get for it. I'm pretty sure I understand the idea of what I need to do, hook the pre out sub rca cable to the amp, which I can then connect to the sub with regular speaker wire, I'm just not sure what type of amp I need for this.
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 4360
Does your AVR have built in bass management (i.e. can you set the LFE crossover point on your receiver)? If so, then any mono power amp will do. I heard of people using the Outlaw 2200 mono with good results. You could also look at Parts Express for a cheap plate amp.
Need to Register?
Forgot Password?
Enable HTML code in message
