EQ 8 Harmon Kardon and Pioneer SX 3800 Older Receiver
Username: Djm123
Can someone tell me EXACTLY how to hook up the EQ to the Receiver...My receiver has been in the attic, yea there is dust there, it sounds VERY muddy...
It seems like I am getting No EQ...I know with the nature of the two components it should sound VERY much clearer?????
I am confused on this one and NO I do not currently have a cassette in this.
Username: Jan_b_vigne
Dallas, TX
Post Number: 15325
Out goes to in. Tape out goes to EQ in. EQ out goes to tape in. To engage the EQ, engage the tape monitor.
Username: Superjazzyjames
Post Number: 396
You should clean that dust out too. It will hold heat in. Your receiver needs ventilation.
Need to Register?
Forgot Password?
Enable HTML code in message
