I am finally making the leap to hard-wire my living room for sound. For aestheitc reasons, I am avoiding floor-standing and bookshelf speakers. The room is a decent size, say 30' x 15'. I was thinking of wiring four ceiling speakers, two for each channel towards the corners, and a subwoofer for added bass on the floor. I'm wondering if anyone has any good suggestions on products. The speaker wires will run to a utility closet where I will have the receiver. Also, I just hooked myself up to the Sonos system so that will drive the tunes. As far as I can tell, that's all I would need. The living room is only used for entertaining with music, so I'm not sure I would need the full front/center/rear channel set-up but I'm open to any advice. Thanks.
Thanks. I've been looking at those Angstroms and they may do the trick. I'll also preface I'm not averse to wall mounted, but I chose in-ceiling because I'm not sure I'll find what I want. I ultimately like the look of the Bose Acoustimass set-up but I am trying to avoid Bose products at all costs. If you have any suggestions for smaller corner mounted (with subwoofer as well) I'm open to that also. I don't need a lot of power in the system so I thought the ceiling mounts would do the trick with the four corner coverage and woofer for some extra kick.
