NAD T763 No Sound
Username: Dbnh77
NH USA
Post Number: 24
Does anyone have experience with the NAD T760 series?
I have a T763 that's worked great for years. I was usig it yesterday without any issue. This morning I moved it and when I turned it back on I'm not getting any sound from any sources on any channels.
I've tried all the standard stuff...check channel levels, shut off tape monitor, etc etc but I"m getting no sound and it's really making me angry.
Username: Nuck
Post Number: 15383
Triple check what you double checked already, Dana.
Check the manual or website for a default reset.
How long was the unit powered down when it was moved?
Leave it powered off for a day then try again, get the reset procedure in the meantime.
Cheers and good luck!
Username: Dbnh77
NH USA
Post Number: 25
Thanks Nuck.
I actually took the case off and blew all of the dust out of the unit.
After that it started working.
The only thing I can think of is that before I moved it the unit was plugged directly into the wall. After moving it I plugged it into a Panamax power conditioner high current outlet. Do you think that could have had anything to do with it?
