Having trouble no getting sound through receiver DENON AVR-391
Username: Steveo0325
How yall doing im getting all my video through the receiver but not sound i use all hdmi cabels but i cant get the receiver the play sound for whats on tv the recevier is a DENON AVR-391
Username: Nuck
Post Number: 15384
Is this a cablebox or a satellite tv connection?
Did you just now make this new connection, or has it worked previously with YOUR setup?
Username: Superjazzyjames
Post Number: 23
You might have to open the menus in your sources (cablebox, blu-ray player, etc) and switch the audio signal to HDMI. Check your owner's manuals.
Post Number: 49
You might also want to check the receiver manual if there are multiple connection paths for the audio. You might have a choice between, analog, digital coax, digital optic and hdmi as possible choices. The factory default setting might be something other than hdmi.
