I finally have my whole setup coming together and I think I am over-thinking the wiring aspect.
I actually got ahold of an old school US built eclipse amp to power my front stage (CDT HD-62's).
It is a 4 channel 60x4@4ohm or 120x2@4ohm bridged... I figured I would use the bridged channels.
How exactly do I wire up the components to get a 4ohm load? or should I just set everything on it's own channel (do tweets/mids get the same power? assuming they do since they are normally hooked up together)
If anybody is curious the setups is....
JL HD750/1 powering a 13 w5 Eclipse 120x2@4 HD 62 CF - with the ACTV crossover A bunch of Second Skin Damp Pro to put on the doors. Oh and a Pioneer 3200bt for the source.
