I can get the 41 online for about $380 delivered and the 43 for about $500 delivered. Is the $120 worth the upgrade? Or should I go with the 41 and buy a center speaker.
BTW: I have Klipsch fronts and old MTX bookshelfs that I'm using as surrounds
Jarom
Do not buy the VSX-41. It is worth the extra money for the better remote and THX certification.
Don
Actually the guts of the 43tx are much....MUCH more high quality than the 41tx. From the 43tx on up you get the good stuff!
