I need wattage! Help !
Username: Retnoucs
Hi everybody
I have a pimped hifi chain set up in my bedroom. In the chain i have 6 speakers wired to an amplifier. I have wired the speakers correctly so that i do not have any impediance issues (2 in serie, one parallel).
This setup is useless unless i add some extra power into the chain.
My question now; how do i add this extra power?
1. can i simply put an extra amplifier in the chain?
it would look like this: ipod - amp - amp - speakers
2. do i have to split my speakers over 2 amps?
result: ipod going to 2 seperate amps going to seperate speakers.
3. are there any other options?
please help!
Username: Jan_b_vigne
Dallas, TX
Post Number: 14937
You cannot parallel the outputs of one amplifier to the inputs of another.
Username: Retnoucs
they wouldn't be parallel, it would be a series circuit if the output of one amp goes in the inputs of the other amplifier.
Is this impossible? would your amp be broke after a while?
Dallas, TX
Post Number: 14938
You cannot series connect the outputs of one amplifier to the inputs of another. Both amps will be broken in short order.
Need to Register?
Forgot Password?
Enable HTML code in message
