New member Username: DanandtamPost Number: 1 Registered: Jun-10 | i have a sae tuner, preamp and amp, a onkyo eq, and kenwood cd player and i don't remember how to hook them all up together. please help |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 14921 Registered: May-04 | . Each component thinks of itself as the only thing out there. Each "in" needs an "out" from the upstream component and each "out" must feed an "in" downstream. Tape and eq goes "in" to "out" and "out" to "in". If that doesn't clear it up for you, you can do a search engine that provides diagrams such as; http://www.prillaman.net/ht_info_8-wiring.html . |
