Putting everything together...
Username: Dannyalasfar
I have 2 floor standing speakers and a subwoofer, all of which are relatively low power. I need an amp to put it all together but cant seem to find one that takes 2 speakers and a sub.
If I bought a 5 channel amp can i just use 3 channels one of which is the sub?
Danny
Username: Jan_b_vigne
Dallas, TX
Post Number: 14880
Seems a waste of money to do so. You only want a stereo amp? There are numerous models available. What's your budget?
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 3920
The the sub passive (meaning there is no built-in amplifier) or powered? If the sub has it's own amp, all you need is a half decent 2 channel receiver or integrated amp.
Username: Nuck
Post Number: 15025
Does the sub have a cord to plug into a wall socket?
Username: Dmitchell
Post Number: 3921
A better way of finding out...
Post Number: 7
yes the sub is active! (cord into mains!) im looking at a receiver instead of an amp...
Username: Magfan
Post Number: 1182
Does the sub have speaker binding posts? If so, you're in....and can use virtually any stereo receiver that strikes your fancy.
Post Number: 8
Well they are spring clips.
I've picked one of these up for £25 from ebay,
http://www.son-video.com/Rayons/HomeCinema/SystHCComplet/EltaxDAC280.html
Rear view is 1st image down the left column, I just want to play music through a 3.5mm jack, a phono cable through aux1/2 will work fine right?
