Dennon avr 4806 shutting off
Username: Cchamp99
I have a nice Dennon 4806 that is shutting off of my when I turn it on. There is nothing hooked in at this point because I am just about to
hook the speakers, tv, dvd,etc. to it but because it is turning off right
after I turn it on, I haven't been able to run it. What might be the
problem?
Username: Magfan
Post Number: 1112
It turns itself off with NOTHING connected?
Unless you are comfortable doing some troubleshooting, I'd take it right down to a pro.
Sounds like some internal protection circuit is thinking there is something really wrong.
Username: Cchamp99
Thanks I figured that was going to be what I needed to do but just thought I'd ask anyways. Thanks
