Alpine type x configuration jumpers
Username: Jonnrall1993
Post Number: 7
how do i hook the configuration jumpers up when i have the sub wired at 2 ohms? do i use 2 or only one? thanks.
Username: Jrbay
Livonia [Detroit area], Michigan USA
Post Number: 1226
Greetings Jon,
You have posted to the Home Audio forum and even if you are using your Alpine in your home you may have better luck in the Car Audio forum.
