Silver Member Username: EzntnGreeneville, TN Post Number: 170 Registered: Apr-09 | ![]() Imagine the time we spend with that high dollar stylus going round and round in this thing /http://www.boingboing.net/2010/03/16/vinyl-record-groove.html |
Platinum Member Username: ArtkAlbany, Oregon USA Post Number: 12360 Registered: Feb-05 | Works for me! |
Gold Member Username: My_rantzGold CoastAustralia Post Number: 3058 Registered: Nov-05 | Yeah, but you gotta wonder why! No wonder those things make a noise. ![]() |
Platinum Member Username: ArtkAlbany, Oregon USA Post Number: 12381 Registered: Feb-05 | Beautiful noise ![]() |
Gold Member Username: My_rantzGold CoastAustralia Post Number: 3081 Registered: Nov-05 | The picture makes me wonder if vinyl would sound better if you lubricate the groove with oil! ![]() |
Silver Member Username: MagfanUSA Post Number: 980 Registered: Oct-07 | Yes you can....and at the same time ruins your cart. I used Armor All as a desperate / last measure once and all surface noise disappeared. The cart at that point simply could not be kept clean for even one side of the disc. Petrol based oil may act as a solvent? It may also be possible to *build some lubricity INTO* the vinyl at compounding. Any lube would have to be able to take whatever temp was needed to liquify for pressing. Silicon oil might work....or simply gum up the works. Over in the thread on phono preamps, Jan indicated that silicon oil has fallen out of favor for cue arm use. In the pic at the start of the thread, is that a NEW disk or has it been spun and if so about how many times...... |
Silver Member Username: EzntnGreeneville, TN Post Number: 174 Registered: Apr-09 | Of course its new. If it was old and well played, you could see the grooves from the other side ![]() |
Silver Member Username: MagfanUSA Post Number: 983 Registered: Oct-07 | Good SEM work. Is there a top view available? How about a compar-o with a well played disc? |
Platinum Member Username: NuckPost Number: 14795 Registered: Dec-04 | Hey there's my car keys! |
