Differend brand fronts and rears????
peach
Anybody had any experience with front and rear speakers of different brands?
Username: Kegger
MICHIGAN
Post Number: 704
yes i have peach and my oppinion is that it doesn't
really matter.
and if your thinking in terms of surround music.
having the three fronts the same or simular/brand
or at least timbre is almost a must.
and then your rear speakers should be full range speakers.
and this:
"having the three fronts the same or simular/brand
or at least timbre is almost a must."
would still be true for movies.
while less than full range speaker work fine for movies
in the rear.but full range should allways be upfront.
peach
Kegger, thanks. I already have the three fronts of the same brand, and am interested in delving into multichannel music. I am going to upgrade the fronts at some point and thought I would go ahead and buy the rear speakers of the brand I am going to upgrade to. I have polk tower speakers now so it would be ok to buy Paradigm, PSB, etc???
Username: Kegger
MICHIGAN
Post Number: 708
i my oppinion no problem peach!
