Help me ..please JENSEN XA 1120 AMP
Username: Mini_t_dude
I just purchased a jensen XA 1120 amp and i have it in my home system hooked up to a rv battery but whenever i hook the battery up the power light doesnt come on and theres no power going into it. I checked all the wires and they were fine but near the back where i hooked up the battery it says between the +12v and the Gnd for ground it says RMT which i think is for a remote and when i researched it i think it should have a remote but im not quite sure, so can someone please help?
Username: Kegger
MICHIGAN
Post Number: 718
basically the remote wire tells the system to turn on.
so you either need to connect it to the same source
you are allready using or some other form of 12v
supply.
maybe even your reciever or something else has a
12 volt out on the back of the unit to turn other
things on.
